what are you going for, grip or show?
for grip just get the autozone special ...
http://www.fordcontour.org/index.php?&autocom=registry&cmd=view_mod&MID=867&CID=163
if you want show go with autovation, but they are slippery when wet, otherwise grip great
http://www.fordcontour.org/index.php?&autocom=registry&cmd=view_mod&MID=619&CID=121
for the autozone ones.. how did you mod the gas pedal.. did you use longer bolts?
kinda off subject but i need your opinion.. my heater control.. it only works on high and not the other speeds.. what do yah think might be the cause of that
I think you would get better answers starting a new thread in troubleshooting.
Just screw them into the pedals. Brake is metal so it's hard to do. You'll probably have to take the panel under the steering wheel area off to fit a drill in there.
drilling through the steel?? that would be a bit tuff!
Drilling through the stock pedals sucked!
i like those pedals for the cougar!!! what model did they come out of![]()
