F'n Circuit City!
F'n Circuit City!
Okay... I gotta rant an rave first about circuit city.... LAZY MOTHER F'ERS, Premium sound Contours/Mystiques are the EASIEST factory amps to bypass!!! Then the explorer, which would be number 1, but the fact that you have to rip half of the rear quarter off to get the eliminator harness in makes them suck.... As you can see from your pics, Cicuit City loves to be pussy little *******s and use their adapter harness up the wazoo... They brand specific deck adapters that connect to that nice rectangular plug, then they just go choose the right car adapter and plug it in.... In your case they got lazy and just used the integrator harness which usually 1 of 2 things happens with that.... 1. the connections aren't the greatest and speakers start cutting out... or 2. the amp eventually blows out and if they were to put the factory radio back in... **** won't work.... or the odd 3rd option... **** doesn't break and it actually lasts for the time the person has the vehicle..... eventually though it's going to go out.... It's better to bypass the factory amp because all after market decks have their own amplifier.... so you'd be double amplifying the signal coming off your deck, the deck amp, then the factory amp, which usually causes the volume once it's turned up to like 10 to be overwhelmingly blarring... sometimes it does, sometimes it doesn't, depending on the vehicle and the amplified system... (BOSE, JBL, Ifinity, etc) Anyways though.... This example of circuit city makes me feel soooo much better about how I do my installs, and that I know more than they do because we have more installs come through then they do.... Alright, on to how to bypass though... very very simple, as long as you go buy the right harness.... Working at BestBuy I know it would cost you $19.99 if you were to get it in Madison, WI. It's a Metra harness 70-5514, Ford Elminator Harness...
So here's my reply......
In the picture Bottom Of Amp, The blue circle is the factory amp output to the speakers, the green is the Keyless module, used for lock un-lock and trunk opening on the key fob.
Picture - Front of Amp - Blue is Factory output again, Yellow is the keyless module, and green in the factory input, which is the opposite end of the plug that is zipped tied in your dash.
Picture - Dash Connection - This is the connection (circled in red) I was talking about earlier in this post about 1. having bad connections 2. the factory amp burning up... I would tape it up just to make it look clean...
Picture - Integrator Harness, the equivalent of what they used on your car...
Picture - 70-5514 - Harness they should of used...
