biminiLX
Ideally tie rod should be parallel to the road.
-J
-J
um, no. ideally the tie-rods should be pointed at the instant centers. that may or may not put them parallel with the ground.Ideally tie rod should be parallel to the road.
-J
To the OP- if you can't swing more than $600, I would suggest that you not do anything for now. Getting the springs and struts is just one step. You're going to want to replace some stuff while you're under there (as I found out) which will probably cost about as much as any budget spring/strut combo you might come across.
