1999 Mystique/ztech 4cl.
Ok now the front end sounds like it's grinding bolts and wal-nuts as I drive. Scraping metal turning right and just awful.
I put the front end in the air and put it in drive to see what was going on(I was safe) I let the wheels free wheel in drive on jack stands. On the right the wheel bearing is shot because I hear it grind and the wheel chucks. On the left it seems ok, but it sounds like everything is gone.
Will just a bad bearing sound like the entire front end is falling off?
I tried yesterday to fix it, removed everything to take the spindle off, but that damn Torx head bolt stripped so now I can't remove the pinch bolt on the lower ball joint. Now I have to remove the entire control arm with spindle attached and get it heated up and remove that bolt somehow.
Why don't they just put a regular hex head bolt there? A torx head? It stripped out in like two seconds when I put the wrench to it.
When that happened I kicked a bag of tin cans across the floor. So frustrating. I hate FWD cars so much.
