Hi!
Thanks for your interest. I changed the transmission fluid at 122,000 miles so it only had 28,000 miles on it and it was neary as clean as new. I have a 35 gallon can on wheels with a clear plastic hose up the side to tell me when it is getting full and this was the only oil in the barrel and it looked very clean while draining and appears to be the same color as new in the tube. The OD light never flashes except when I push the button to take it out of overdrive. Yes, it winds up nicely in first gear and shifts into second with some slippage and with every upshift after that. It takes almost no throttle increase to make it shift down though, a small incline and it shifts out of overdrive, which it never did until recently. I expected this rebuilt/refurbished transmision to last more than 50,000 miles but the symtoms are the same as the first one at 94,000 miles. Maybe the rebuilder cut some corners or something but he has a good reputation locally and that is why I used his services. Then engine has never used a drop of oil and doesn't leak anywhere. It has had the normal problems with vacuum leaks and coil packs, also the valve cover leaked letting oil onto the spark plugs. It has had 2 timing belt kits also. Other than the aforementioned, that is it. It still gets 30+ mpg on the freeway at cruising speeds. As well as it pulls from a dead stop I can't think that the engine is getting tired. It also passes smog tests here in California with flying colors. I have always used Castrol 10-30 in it as that is what I use in all 8 of my Fords except my F350 diesel. I was hoping someone would have an easy fix but it isn't looking good at the moment. Thanks to everyone who commented, I will let you all know what happens next when it happens.
