svtkev
finally got my headers today so my 3L swap begins tomorrow,plan to be done monday because we leave for vacation on tuesday , heres some pics of my parts pile
left to right..
port matched 04 escape heads, bugzuki intake plates, new ford exhaust manifold gaskets, new ford 3L head gaskets, 3 qts royal purple synchromax trans fluid, new ford front crank seal, new ford oil pan gasket, new svt throttle body gasket, spec stage 1 clutch kit, new ford throw-out bearing, fidanza flywheel, new ford axles, 2 ac delco serpentine belts, 3 bolt exhaust flange gasket, mil eliminators, motorcraft pcv valve, new cloyes timing chains , guides and tensioners(2.5 for svt cams), ac delco cabin air filter, fram fuel filter, xtreme coated msds headers with y-pipe, fel pro 2.5 head set, mobil 5-30 oil for first 500 miles then switching to royal purple 5-30, purolator pure-one filter, 2 sets fel pro head bolts, on the stand 04 escape 3L 14,000 miles, with newest version oil pan, tube and tray
Heres what its all going in
left to right..
