FrancisPennysac
OK so basically, on occasion my turn signals either won't come on, or will come on and shut off.... It does this randomly back and forth. Sometimes ill drive for 3 hrs with no problems...other times I can't even get them to continue to blink more than once without having to "play" with the switch.
I have replaced the turn signal switch itself.. and the old one does the same thing.. i am looking into the relay although i would think they would either work fine or not at all if relay was the case.
Now just simply touching the switch is enough to get a blink or two out of them, so as im sitting at a stop I must "play" with my turn signal switch just to make it seem as if my blinkers are working fine.. My question is...is there any connection to the "clock spring" the car was in a wreck,AB did deploy, I have the "3-2" airbag light code. Im wondering if it is somehow connected to my turn signal problem. Now ive owned the car for about a year and the turnsignal problem just started back in october. Ive had the airbag "3-2"code light on since Ive owned it. Everything else electronically works fine i.e. horn, cruise, hazards, heat, radio, instrumentation.
So any ideas?? I had the steering collum apart and checked for broken or shorted out wires, didnt see anything. Should I change the relay to be sure?? Im tired of shooting in the dark and yes I should invest in a halfway decent multimeter...
On a side note? If my airbags are already deployed and dont work, how do I get my airbag light "3-2 code" to STOP blinking WITHOUT replacing the airbags/sensors? I cant just remove the bulb as it will beep. Can I just remove the whole system?? as I have zero plans of putting airbags back in. I know it controls the pre-tensioner on the seatbelts so would it render my belts useless if I remove it?? I know these are vague but im at my wits end...and I managed to get everyother light on the dash to NOT come on
but now that hideous orange blinking monster rules my dash at night time and holy f*ck is it ANNOYING... so any help would be GREAT
