SniperUML
OK i know there are like 100 ac threads open right now but nothing with my exact symptoms. My 99 contour se stood for about a month when I was on business, started it up Tuesday without an issue, kicked on the ac it it blew out ice cold like always. Went to go use the AC again on Thursday and all of a sudden its not working. Now I checked the R134 level and its fine (alittle low so I topped it off), got down on my back and had my girl friend cycle the ac switch to see if the clutch engages and it doesn't. I did have the problem where the relay was going and the ac was on all the time, I never replaced the relay. Can I assume that the relay died completely since it all of a sudden doesn't work. I mean blows out warm air. I am assuming if the clutch was going it would slowly get worse and then cut out not stop all together. Any ideas let me know.
How much does a compressor go for anyways?
Thanks,
~Dan
Thanks,
~Dan
