For Sale 98 CSVT 3.0L swap
Status
Not open for further replies.
powellj
Kansas City
great running car alot invested, need to sell asking 5k OBO NEED TO SELL MAKE OFFER
call, txt or emal
thanks
Pics on craigslist ad
http://kansascity.craigslist.org/cto/4651429839.html
ABOUT 11K MILES SINCE SWAP;NEW PARTS INSTALLED LESS THEN 14K AGO.
*NO DYNO TIME ON ENGINE/TRANS/CLUTCH; ONLY DATA LOGS.
*NEVER RACED OR ABUSED.
*TRANS BROKEN-IN FOR 1000 MILES ALONG WITH CLUTCH.
Engine:
* 2006 Ford Escape 3L (only used Mobile 1 since swap; 6 qts.)
* Nautilus Performance Lower Intake Split-to-Oval Port Conversion
* Nautilus Performance Fuel Rail Block w/ New FMC FPR
* SVT Upper Intake Manifold
* 19# Injectors (ORANGE SVT)
* Lightened and reduced-size Power Steering and Underdrive pulleys (Red)
* New FMC plugs and FMC wires.
* All new rubber coolant hoses
* New Waterpump/Serpentine belt
* New A/C compressor & condenser
Intake:
* Stock intake tube/filter
* P.R.T. optimized TB (63mm)
Air/Fuel and Tuning:
* Walbro 255 LPH Fuel Pump.
* SCT X-Calibrator 2 PCM programmer (three tunes uploaded)
* Innovate Wideband (not installed properly)
* Standard SVT tune
Transmission:
* Livinsvt (Brett Powell) built transmission
* Focus Shift tower
* Improved/newest shift forks (FMC)
* NEW SVT Clutch
* New SVT flywheel
* Torsen T2 Limited-slip Torque Biasing Differential (FMC)
* B&M Short-throw Shifter
* P.R.T. Urethane-filled (type 94A - stiff) Transmission Roll Mounts
* All new bearings (FMC)
* All new seals (FMC)
* New TOB/Master/Slave cylinders (FMC)
* New Hoses
* New Half Shafts
* New shifter bushings
* RP Synchromesh MTF fluid
Suspension Upgrades:
* Koni sport shocks/springs
* Beefy (custom) camber plates
* NEW strut mounts front
* sub frame connectors painted black welded on
* tubular toe control arms powder coated black; rear (Redcoat Raceworks)
* spherical end-links rear (Redcoat Raceworks)
* Custom adjustable sway bar end links front
* B.A.T. reinforced sub frame
* B.A.T. 21MM sway bar w/ poly bushings
* NEW CONTROL ARMS
* NEW KNUCKLES/HUBS
* NEW WHEEL BEARINGS (ALL 4)
Brakes/Tires:
* Mintex pads front/rear
* drilled/slotted rear rotors
* Continental Tires with low miles
Aesthetics/other:
* Recaro SRD seat w/ 5th belt
* Momo shift knob Air Race
* fog lamp delete
* Windshield washer delete (never needed it in California)
* SVT floormats front and rear
Audio/Electrical:
* VDO gauges in custom bezel; {oil temp, oil pressure, boost, WB}
* Pioneer AVIC-N1 w/ voice Head Unit (2 DVDs; 2 software versions)
* MB quart reference speakers front; Eclipse speakers rear
* Optima red-top sealed battery
* Moroso battery relocation kit in trunk (passenger side)
Included with SVT:
*Original Radio head unit
*CD's of various tunes for different combinations
*CD's of photographs of SVT
*stylus for touch screen
*trunk jack/spare tire
*custom metal Knoi knob
*2 sets of Ford keys WITH key fobs, 1 accessory key (three total)
*2 3" binders full of documentation
Status
CLASSIFIEDS RULES
Last Updated: 7/20/22
