GrimmSVT
Didn't know if this was right place or if needs to be in Common Intrest,please move if wrong.Just need to know how hard it is to remove and reinstall a clutch kit out of a 89 Tempo with the four cylinder.In process of swaping a zetec out of a wrecked cont and into a good cont and don't want to get into and PITA job.Also can anyone tell me if I am correct in thinking that is in the clutch,pressure plate and bearing that is bad on the car.Car starts fine in neutral ,push clutch in and then try to put it in gear then it grinds.Strart car in gear with clutch in and sometimes it grinds and kicks it out other time its just make a little noise.Once moving you can not shift to other gears without forcing and causing a lot of grinding. TIA
