I<3mycontour
So for some reason whenever I try to whip it into 3rd gear (2.5 duratec slow edition) It grinds like hell, but if I ease it up to the gear and hold it there gently it just slides in, any ideas as to what this could be?
well what can I do about it?
I would just shift genlty to prolong the life, otherwise you are going to have to rebuild the tranny soon. Make sure your cable ends are not too worn otherwise the shift tower wont fully engage 3rd during a "jarring" shift
if the cable ends are worn then you will see issues with all gears, not just third. this is a syncro issue and the mtx is going to have to be rebuilt. fresh fluid is just going to cover it up. repair it before any more damage is done and it costs more to fix.
You can also make sure the shifter is not loose. Pull up the leather boot cover and make sure the two bolts are tight that hold the assembly to the car. I added two more bolts, as it seems it can take four and either Ford or the assembly guys only added two.
