This winter I decided to delete my ac.
At the time I did not realise I had a escape timing cover.
When running an escape cover and deleting ac you cant run a tentioner.
remove your tentioner from the cover . Use a bolt that matches the thread(ill edit this to add corect bolt size) about an inch long. Add some black rtv to the threads and landing ,as the threaded hole is open and can leak.
Block your wheels
jack up the passenger side and place on jack stand.
remove wheel.
remove splash sheilds.
you will need to buy a belt 51inches long. This size work for me, it may be different for you.
the belt you choose will seem too short. You have to stretch the belt on. Its esiest to stretch at the crank pully. Once stretched on put your stuff back on and try it out . Any questions please ask.
Block your wheels
remove wheel.
