CKtour98
I put in an 04 full 3L. With the car idling for 10 minutes, the small hose off the reservoir to the thermostat is hard (good sign) but my upper rad hose on the driver side is SOFT, all it does is get very hot but I can squeeze it no problem, even after the fans have kicked on and turned off 3+ times its not hard?
Whats my issue here? Ive had the reservoir cap off trying to bleed it and nothing seems to work, even putting the fans on high and idiling wont do nothing. Inside the car there is plenty of heat when its on, and after 10-15 mins the coolant reservoir started to have steam comnig out but wasnt boiling.
Bad thermostat? Bad waterpump? The hose off the bottom of the waterpump to the firewall is also soft...maybe a bad waterpump belt, if not the pump...?
