Blackcoog
I swapped a ported 3L into a 1999 Cougar ATX. The engine setup is as follows:
-2005 3L Taurus with ported heads
-Porting plates installed with gasket sealant
-SVT lower intake
-19lb Mustang Orange EV1 injectors (plugs directly into the return harness)
-SVT upper intake
-SVT throttle body/cable/bracket
-BAT intake pipe with K&N filter
-MSDS headers
-Aftermarket Y pipe
-Stock Cougar single exhaust
The car started fine but it won't idle in park. I can give it gas to keep it going. I can put it in drive and that for the most part keeps it running except for the occasional stall at idle. It will drive fine. I had a CEL for the IAT sensor which I cleared and it hasn't returned. Sensor seems fine.
I have a Xcal 3 with a tune from Nautilus for the car which I loaded up but the idle issue is still present. Nothing changed with the tune.
I then tried swapping parts. I swapped the idle air controls sensor, MAF, and throttle body over from my car without any luck. I removed the upper/lower, verified the injectors were firing, and put it all back together carefully to check for any obvious signs of vacuum leaks. I didn't find anything and to me it doesn't seem like a vacuum leak issue. Usually you can hear a large leak. I noticed that when the MAF is unplugged the car will idle and run perfectly..... WTF? I thought I'd give the stock tune a try again but when I tried to load the stock tune back in (Xcal 3) it says "unlock ECU failed"...
Anyone have any suggestions/ideas/thoughts?
Thanks,
Chris
-SVT lower intake
-SVT upper intake
-MSDS headers
-Aftermarket Y pipe
Thanks,
Chris
