Kinyoto
I have read the other post relating to my problems but I felt I needed to start fresh to get the advice I need for my problems so here goes...
I've got a 98 CSVT with a full 3L swap from an '03 Taurus and I have it tuned from Nautilus using an X-Cal2 device. Everytime I flash it I get two error codes right off the bat (p1000 & p0602) both of which I have read as much as I can find on them, which is not much, other than the 1000 doesn't do anything and the 0602 I don't know what it does but I have found that it can be turned off in the tune. Now after I start the car and drive it for a while after shutting it off I then have a p1506 IAC overspeed error. From that point forward It starts going downhill the longer I continue to drive it.... I will get a random misfire code (p0141) which comes during the mid range rpms more than anything and then the more i run it the worse the misfiring will get. Will the 1506 be the cause of this? I have replaced the IAC with a new one and the code still comes back so what else should I be checking? I tried to check the voltage but I don't really know what it should read??
Any Ideas??
Any Ideas??
