CSVT #939
CAR STILL FOR SALE....MAKE OFFER (New link posted for Viewing Car on Craigslist)
2000 Ford Contour SVT with 70,861 miles. Silver Frost Exterior with Navy Blue Leather Interior. Manual Drive, Seats 5, and has a sunroof. This Contour is #939 of 2150 and has a 3.0 Bottom Block instead of the factory 2.5. There is a Booklet of paperwork describing the mechanical history of this particular vehicle. There is some minor damage to the Driver's side Front Fender. We have the original front grill but the tabs were broken when fender damage happened. The heat work but the a/c is not working (the compressor is good but there is a hole in the condenser coil so it will not hold a charge). This car runs great and gets good gas mileage as long as your easy on the pedal. Check engine light is on because the rear O2 Censor needs to be replaced. The middle seat belt in the back seat is broken (Unable to pull out). About 3 years ago (7-21-11) the transmission was replaced and still works great. Also at the same time a clutch kit was put in as well but I would say the clutch pads would need to be replaced. Also included in the sale is some extra parts including the old Transmission, which are rebuild-able, and a set of 4 matching Cam Shafts purchased from a member of contour.org. Asking $2000 OBO.....CONTACT SARA AT 803-468-657 youtubevideo http://youtu.be/xRmbS1aVmzs
