I recently installed a new timing belt, tensioner and related guide pulleys on my 99 Mercury Mystique.
I took my time and done it all up the right way and she purrs like a kitten and drives great.
I left the top timing belt cover off for a few miles just to make sure tension stays true and to inspect things after a short drive. All looks great, but I noticed the tensioner guide that has the allen key hole, moves its little arrow pointer/guide back and forth a little bit while the engine is running. I am assuming this is normal and that it constantly adjusts its own tension or something even after initial tension setting.
I also noticed the little adjustment ear/guide is now pointing way down from where I set it according to the instructions, that say the ear must be lined up with the line in the guide as you turn the allen wrench up.
Now I wonder if the tensioner went out of adjustment and the belt is to tight again.
Thank you for any guidance.
