For Sale 1995 Ford Contour GL - 2.0L Zetec, Manual Transmission ($800)
Status
Not open for further replies.
lycc825
Bothell, WA
First, I want to thank this forum. You all have helped me a lot. Now, it's time to sell the car my wife's first car she's owned since high school. It's nothing special, but a couple minor repairs can get this thing back on the road reliably. We are located in the Seattle, WA area.
Owned this car in the family since July 2006, Been reliable with regular maintenance, until now the check engine light came on and it doesn't run as smooth as before. No time to diagnose so we bought a new car. Upon research, it may need a new EGR valve or PCV valve which are cheap parts. Recent oil change and coolant flush. I've done most maintenance to the car with a few trips to the shop for bigger services. I have most, if not all, receipts for the last couple years. The car is can be reliably driven in the Seattle area, but I'd recommend getting the engine hesitation (details below) fixed before going anywhere far.
Clean title, 197140 miles, VIN: 1FALP6531SK196185
New in the last 15k miles:
Timing belt
Water pump
Battery
Serpentine belt
Spark plugs
Valve cover gasket
Tires (Les Schwab, 60k warranty)
MAF sensor
Ignition lock cylinder
The good:
Quick acceleration, peppy engine
Good gas mileage (average over 30 MPG on mostly highway driving)
Power mirrors
Heat climate control warms up quickly
big trunk
Still have original spare, jack, and lug nut wrench
Flip up sunroof
No rust
Brutally honest, the bad (almost all cosmetic):
Dents and scratches
Radio wiring cut behind the radio from a theft attempt (original radio put in place to fill void)
Center console trim missing from the same theft attempt
Front passenger door does not open from outside (security feature?)
Interior cosmetically isn't something to write home about
Rear passenger window crank missing
Single layer crank on bottom of windshield, cop checked it out and said it's fine
AC doesn't work (probably just needs a recharge)
Rear seat is loose, but seat belts are solid and seat is still usable
Front driver door lock does not unlock from the inside
Air bag has been disconnected for some reason, was like this when we first got the car
Car starts and idles great, but needs to warm up before being driven, otherwise it hesitates under acceleration and sometimes stalls, also hesitates under 90%-100% acceleration
Comes with a Ford OBD1 code reader, Chilton service manual, old DPFE sensor, extra MAF sensor & housing.
Kingsgate area of Kirkland & Bothell.
Can meet most evenings after 6pm. Email with phone/text number and when you can meet.
$800 OBO
Status
CLASSIFIEDS RULES
Last Updated: 7/20/22
