BADEVO
While sitting around testing this theory of my wiring problem I decided to play some more.  I dont really care for the big red strip that runs across the back of the car so I figured since I'm about to tint the taillights I might as well black that out as well.
Heres my mini how to.
Pop the trunk.
Locate and remove the 6 bolts that hold the panel in place 9 3 on each side), they look like this:
Also unplug the wiring harnesses you see pictured. You do not have to remove the bulbs.
Once the panel is removed it will look like this. This is when you use your Total Prep to wipe away all the surfaces you are going to paint.
Using blue painters tape mask off your chrome trim.
Once your all taped up, spray your panel. I justed dupli-color interior paint for plastics.
Once you've let the panel dry completely unmask it.
Back on the car
I know its not all high tech but hopefully it helps someone on the forum.
Pop the trunk.
	Back on the car
