A long time ago, my high school science teacher did an experiment in front of the class. He blew up a balloon and tied it off, then sprayed just a little WD-40 on it. After a couple minutes, the balloon popped. Since then I've shown the trick to other people who used to use WD-40 for everything.
To bring this thread back up: try this. Worked totally awesome!!
http://www.1017.org/nsx/Enginetrick/EngineTrick.htm
Do you hose down the engine bay again AFTER the foaming tire cleaner ???
	When you use the tire cleaning foam. Do you spray it on the engine and then start it and let it run for 30 mins or am I supose to spray it, then wipe it down and then run the car for 30 mins?
May be a stupid question, but do you hose off the engine with it off?
