Changing Brakes
smokespeed
Hey guys, Im a car novice and I am in a serious need of brake pads. I was wondering if you guys think changing the brakes is an easy job or something better left to a pro.
if you take your time and just think you can figure it out if your a first timer. also do one side of the car at a time so you can see how things go back together
Very easy job, I did my front brakes in 15 minutes, pads only that is, I think if you put on rotors too it would tag on another 15 minutes per side. I believe you also need torx bits.
Yup you will need a torx bit, and can get it in a 3/8 drive configuration from Advance Auto or AutoZone.
