enduro
96 V6, MTX, 100k miles
Got 2 codes that came up on a recent test the 0420 and a 0303.
The car runs good and gas mileage is OK
Anyhow the 0420 I'm convinced is a false code. Can the computer be reflashed to reset the parameters for this code? Or, are MIL eliminators my only option.?
The 0303- Engine misfire cylinder 3, checked wire - resistane within spec, checked coil continuity check specs are 12.8 to 13.1 range , slightly out at 13.4 , but I think the - 2 C temp may have skewed that # slightly. the spark plug (4 months old)appeared OK, gap was OK, slightly black but electrode was clean and proper color.
Anyhow , should I just assume the wire is the problem and replace them all or is there anything else I should check?
