svttouruofl
I am seriously considering a 3L swap but I was just wondering how much money I am going to be looking at. I was just wondering what some of you spent on it so I'd have any idea of what to expect.
one million dollars.![]()
Straight 3L swap if probably your best best. Either way you're still going to spend a decent amount of money on it because I wouldn't put a junkyard engine in my car without a throurough inspection including taking off the heads. I think that a straight 3L will probably be cheapest and easiest for you.
FastCougar said:02 Escape 3L Oval Port
- Block R&R
-- reringed
-- cylinders rehoned
-- Clevite77 main & rod bearings added
-- all new TTY bolts on bottom end
- SVT Cams
- All new timing gear (chains/guide/adjusters ... everything behind the timing cover)
- All new gaskets
- Heads R&R with 3 angle valve job
-- All new valve stem guides
-- All new retainers & keepers
- Heads port matched to 2.5L LIM
- New SVT Throttle Body
- New IACV
- New SVT flywheel
- New SPEC Stage III clutch
- Grand Total: $2,505.41
This is a stock CR 3L, running 10:1 CR. I didn't do any chamber work on the heads because I know with proper tuning, this engine could hold 12+psi of boost and put down high 300's in the hp/tq department.
HMS Modified Transmission
- Slick Shift Kit (roller bearing shift forks)
- Keyed Tower Mod (never worry about breaking shifter bolt again!)
- New blockers on 2nd, 3rd & 4th gears
- Torsen T2 Diff fitted
- New OEM TOB/Slave Cylinder
- Total Cost Parts & Labor: $1,163.04
- Torsen Cost: $548.99
- Grand Total: $1,712.03
Combined Total: $4217.44
