Several Problems
neversummer7
Lawrence, KS
Number one... occasionally when I am driving in cold weather my car seems has trouble idling. When I am stopped at a light my car will rev between ~700 and ~1200 rpms.
Number Two... I think it is probably be related to the first. But when I am driving I will push on the accelerator and nothing will happen it actually feels like if had a choke on if i had one on a car. Also when I am driving and I let off the gas and push the break my car will completely die. It doesn't do anything to warn me that this might happen.
Number three... When my car sits out in the cold one of my rear breaks will lock up from the parking break and wont let loose until. most of the time it will let go really quick and other times it will last almost the whole ride home or wherever I am going. This doesn't happen very often but It happened last night so I thought I would ask.
I apologize if this has been asked before I just didn't really know what to search for. Anyway thanks for the help.
1 and 2 could be related. Clean/change the IAC valve and clean the throttle body. Any CEL codes? Take it to Autozone or Advance for a free reading. Then post the exact codes.
3. Need new parking brake cable or don't use the parking brake when it goes below freezing.
Edit. IAC valve
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=7
and this.
Idle Air Control (IAC) Valve
Removal
1. Disconnect battery ground cable
2. Remove the air cleaner outlet tube and resonator assembly.
3. Disconnect the main chassis vacuum line.
4. Disconnect the ignition coil and radio interference capacitor wiring.
5. Remove the fuel line bracket retaining bolt.
6. On 2.0L engine equipped vehicles, raise vehicle on hoist.
7.
7. Disconnect the engine control sensor wiring or fuel charging wiring (depending upon application) from the idle air control valve (IAC valve) at the idle air control valve connector.
8. On 2.5L engine equipped vehicles, remove retainer for engine control sensor wiring from the upper retaining stud bolt.
9. Remove the two idle air control valve retaining bolts or stud bolt (depending upon application).
10. Remove the idle air control valve and idle air control valve gasket.
Installation
1. Note: If scraping is necessary, be careful not to damage idle air control valve or intake manifold idle air control valve gasket surfaces or drop material into intake manifold.
Clean idle air control valve gasket mating surfaces.
2. To install idle air control valve, reverse Removal procedure. Tighten the fuel line bracket bolt to 8-12 N-m (71-106 lb-in).
3. On 2.5L engine equipped vehicles, tighten the retaining bolt and stud bolt to 8-12
4. On 2.0L engine equipped vehicles, tighten the idle air control valve retaining bolts to 8-11 N-m (71-97 lb-in).
TB cleaning
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=920243&Forum=trouble&Words=p0401&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=allposts&Main=919728&Search=true#Post920243
Parking brake
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=2
