paulbecker
New CEG'er
- Joined
- Jul 16, 2006
- Messages
- 6
My Contour (98 2.5 Duratec, 122K miles) has been down for some time now. I've been driving my wife's car and tinkering around on it on the weekends but I'm clueless.
When it got cold here in December, it would occasionally die when I pulled into the driveway. I would start it again immediately and it would seem fine.
Then one day on the way home from work I rounded a corner and the CEL flashed and it was running rough. I nursed it towards home and went to the local AutoZone (yeah, I know) to get the codes read.
I told you earlier that I was clueless - I lost the codes, but I do recall that I got misfires codes and system lean codes, both banks.
I put on new plugs (gapped at 054) & wires, and checked the grounds around the coil pack to no avail. Here's what it does today...
I start it up, let it do its normal high-idle down to low-idle bit, then rev it to 2k RPM and hold it there. It stays there for maybe 7 seconds then starts to nosedive by itself (foot hasn't moved), ending up at about 1.2k RPM. If I take my foot off of the gas it dies. If I instead goose it a couple of times it is fine, and I can repeat that exercise as many times as I'd like with the engine cold. Not sure about warm.
I'm starting to suspect a fuel or fuel delivery problem, but I really have no clue. Any suggestions?
Thanks,
Paul
Thanks,
Paul
