svttouruofl
I have been having a problem at very high speeds with the car shaking violently during a certain speed range. It smooths out once I get above a certain speed...What would cause this and what should I check on my car?
Some of the things which can cause this are:..at very high speeds with the car shaking violently during a certain speed range. It smooths out once I get above a certain speed...What would cause this and what should I check on my car?
Generally, I've found tire balance to be the culprit for this situation. Starts shaking around 50 MPH or so and smooths out around 60-65 MPH. If the above doesn't take care of it, you might want to look at your tires.
....a wheel that won't properly center on the hub (hubcentric adapters are needed with some wheels), ....
......I purchased some rims recently .....
I think that is what it was to because I was around 5Krmps when it started and it smoothed out just before 6K. But this was in fifth gear...Why haven't I ever had this happen in lower gears?
