Hi, I just purchased a 1995 Contour SE with 123,000 miles on it. It's automatic and it shifts hard from 1st to 2nd gear, all the other shifts are normal. Can someone please tell me if this is a simple repair or not. Thanks in advance
Welcome. This is most probably what if known as "Bang Shift". Before you try making repairs to it, try changing the ATFluid first. Sometimes, that is all it takes to fix a ATX problem.Hi, I just purchased a 1995 Contour SE with 123,000 miles on it. It's automatic and it shifts hard from 1st to 2nd gear, all the other shifts are normal. Can someone please tell me if this is a simple repair or not. Thanks in advance
Thank you all for your help, I will take it to the mechanic Monday morning. Have a great weekend all.
ATFluid change in "Duratec Maintenance Read First."
http://www.contour.org/ubbthreads/s...992476&page=0&view=collapsed&sb=5&o=7&fpart=1
If it is not a ATFluid, you have to determine if changing the Turbine Shaft Shift (TSS) Sensor is a repair you want to do yourself or send to shop. Links are provided for both "maintenance issues" .
Edit. TSS change
http://www.contour.org/ubbthreads/s...ber=257675&page=&view=&sb=5&o=&fpart=all&vc=1
and this
http://www.contour.org/ubbthreads/s...er=1030582&page=&view=&sb=5&o=&fpart=all&vc=1
Since I replaced the TSS, I get the 1-2 bang shift all the time now. Before it was very intermittent.
Any more ideas?
