realness1978
Hi,
My horn is not working. I checked the two fuses that are under the hood that the manual listed as pertaining to the horn. One fuse is a 20amp which is used for the horn and the hazard lights. This fuse was good I pulled it out and checked. The hazard lights are also working fine. The other fuse is a relay which is a 12v. I switched the horn relay with one of the high beam relays which is also a 12v. The high beams worked but the horn still did not work.
Does anyone have any advice on how to fix this?
Your help would be greatly appreciated.
Thanks!
Thanks!
