I'm just saying, this is an interesting read:
 There is no good reason why fog lights are yellow.  Here is an
excellent explanation provided by Professor Craig Bohren of Penn State
University:
"First I'll give you the wrong explanation, which you can find here and
there. It goes something like this. As everyone knows, scattering (by
anything!) is always greater at the shortwavelength end of the visible
spectrum than at the longwavelength end. Lord Rayleigh showed this, didn't
he? Thus to obtain the greatest penentration of light through fog, you
should use the longest wavelength possible. Red is obviously unsuitable
because it is used for stop lights. So you compromise and use yellow
instead.
This explanation is flawed for more than one reason. Fog droplets are, on
average, smaller than cloud droplets, but they still are huge compared with
the wavelengths of visible light. Thus scattering of such light by fog is
essentially wavelength independent. Unfortunately, many people learn
(without caveats) Rayleigh's scattering law and then assume that it applies
to everything. They did not learn that this law is limited to scatterers
small compared with the wavelength and at wavelengths far from strong
absorption.
The second flaw is that in order to get yellow light in the first place you
need a filter. Note that yellow fog lights were in use when the only
available headlights were incandescent lamps. If you place a filter over a
white headlight, you get less transmitted light, and there goes your
increased penetration down the drain.
There are two possible explanations for yellow fog lights. One is that the
first designers of such lights were mislead because they did not understand
the limitations of Rayleigh's scattering law and did not know the size
distribution of fog droplets. The other explanation is that someone deemed
it desirable to make fog lights yellow as a way of signalling to other
drivers that visibility is poor and thus caution is in order.
