Bill J. at Team Ford
This just started about 2-3 weeks and it's not a big problem.  It just irritates me when I am driving.  If I am at a standstill with the clutch pedal out, and I move the shifter in any direction at all, and just a little like 1/2" or so.  the RPM's drop from about 650rpm top under 500rpm and it stumbles.  As soon as I let the shifter go or push in the clutch it goes away.
Does it sound like the clutch is engaging early? Because it only happens when at a stand still and at idle. The lever is not in gear mind you, but I am just moving left and right a fraction. You when you shake or jiggle the shifter to make sure it's in neutral, that when it happens. It's when you can feel the rod push against the shift fork I guess.
Any ideas?
I asked one of the guys in the shop and he had no idea.
Any ideas?
