lets get some good information together here about spec clutch failures.
lets keep discussion out of this thread and post only the facts.
post what clutch you have, how many miles where on it when it failed, was it making any noises, etc. post any pictures you may have taken of the clutch also.
The idea of this thread is to document failures to show to Spec.
So I will start
clutch kit: Stage 3+
engine: 3L turbo
break in period: 1k miles
miles at failure: ~7k
Noises: since almost the beginning I have had a squeak at idle with the clutch out. when it started acting up I was getting a spinning/grinding type sound with the clutch pedal on the floor. letting up slightly on the pedal made the noise stop.
Symptoms: could not shift gears with engine running. start engine while in gear and clutch would work.
Reason for failure: springs came out of clutch hub
Pictures:
So I will start
engine: 3L turbo
Pictures:
