iskoos
96 Contour GL Zetec 170k
Some of you will know my case. I had a slight hesitation in the engine and when I asked the first question was: What plugs / how old is the plug wires ...
I had new Bosch Platinum +4s in there and my plug wires(Motorcraft) was about 5 years old.
I was advised very strongly that I should put OEM Motorcraft plugs at the top of my list and replace the wires because it is best to replace the plugs and plug wires at the same time...
Went to Ford dealer. $8.92 for each plug and 80.00 for the plug wires. I said thanks...
I found silverstate Ford and ordered the same stuff from them.
Each plug is $3.90 - Plug wires only $35.00 (kudos to these guys) I got everything OEM and saved %50.
I started a thread here several days ago because the plug gaps were slightly off. I was recommended to gap them to exact specs.
The specs for my car is 0.05inches (or 1.3mm) and the plugs were at 0.045inches (about 1.2mm) out of the box. I regapped them and installed everythig this morning.
How did the car run?
I had to keep my foot on the gas pedal to keep her running. After about 30 seconds, I called it off and removed the new OEM plugs and put back the Bosch +4s back in there. She started running just fine. I left the new spark plug wire set on the car. But from the way she runs I could tell, there were nothing wrong with my old wires set as well...
The car runs fine (I still have that hesitation though but it is very driveable)
Now my question is that : WHAT THE HECK HAPPENED?
You put a 4 brandnew plugs (and they are OEM not aftermarket) and car runs like a crap. And you put back the plugs nobody likes, nobody recommends and they do the job!...
I am just puzzled!...
Now let me tell you couple of things before you start firing at me.
When I was regapping the plugs, I did NOT touch (or come even close to) the tip of the spark plug. I just opened the end wire slightly with gapping tool I have(picture attached) And the amount I changed the gap was lot thinner than a thickness of a finger nail. So it is not that I opened it by a mm. The amount I changed the gap was so minimal I almost found it unnecessary to do this but I did it. Now I regret. I should have just installed them as they are.
I will try and get another tool to see if my tool is out of calibration. That is the only thing I could think of at the moment...
Do you guys have any idea what the heck happened here? How on earth the OEM plugs almost everybody's #1 is not working...
I attached many pictures for you...
