Liquid_force
For anyone interested...
For a couple weeks I had seen my batt light coming on once in a while, usually only for a matter of minutes. Didn't think a whole lot of it.
On a 200 mi round trip this weekend it came on about 50 miles from home and never went off. When I got home I checked V with the engine off -- 12.0. Started it and checked again - 11.65.
Pulled the alt and took it to a good auto electric shop. By the way - thought it was a 130A -- it's 110A. They said they'd rebuild it for about $90 by the end of the day (reman replacement is $180). I said go for it. Got a call in about an hour and the tech said the alt was so torched it wasn't worth rebuilding.
Told him I have a high power sound system and he said when I get the new one in to come by and he'd test it for me.
I have 1000w class D sub amp and 180x2 a/b for the fronts.
Voltage w/engine off was 12.6, at idle it was about 13.7 (battery had been pretty badly discharged before I got the new alt in -- it turned over slow). I put in some bass mekanik w/volume close to or at the edge of clipping (I rarely listen that loud). Voltage sagged to 12.5-12.8 and current was varying between 30-60. The tech seemed a little wowed.
Older guy. Seemed cool w/audio but I don't think he had any idea people are running that kind of power.
He seemed to be as worried about the weak battery eating current as the amps.
He also pointed out a smell like burned plastic and said it was due to the alt charging so hard it was burning the coatings off its internal parts, and the alt would probably be hot enough to physically burn you if you touched it.
Dude told me a cap might help (!?!?!) I wanted to ask his logic on that one, but it was 10 min before close so I just let it go.
Anyway - just an interesting learning experience regarding current draw and its effect on the charging system. I thought some of you running a lot of amp power might be interested in.
I guess the lesson is if you're running ~1200w or so and you pound on it very often your alt is probably on borrowed time.
I got one with a lifetime warranty, so even if I have to change it every year or so I'm ok w/that vs big charging system mods.
I'll look into a good battery when this one dies -- that's about it.
