Mystique 96 Rims
intravino
Montreal
Hey Gang,
I just purchased a new 2009 Focus S.
I am keeping my 96 Mystique, can my extra 14'' steel rims (for winter) be used on my Focus?
I think it is the same bolt pattern?
Thanks,
Intravino
the focus did share the same bolt pattern, did it change for 2009, I have no idea ...
... you have both cars there, try it out and let us know ....
what size are the stock Focus wheels? my dad just got an 09 Focus SE with the 15" alloys and they barely fit around the brakes. you might need a 15" steel wheel. i'm thinking the front calipers and rotors are close to that of an SVT.
edit: just checked front caliper size. its 10.8", which is 274.32mm SVT's which require 15" rims are 278mm or 10.9" so i'm gonna say no to the 14" steel wheels.
The tires are P195/60R15 and the rims are: 15x6.0
It looks like it won't work. :(
Thanks 95 Mystique.
A 15'' steel wheel from a Contour should work ? yes or no ?
Thanks,
it should. the Focus kept the 4x108mm bolt pattern, and the back spacing should be close to the same, so yea, the 15"s should fit.
