mynewmystique
New CEG'er
[99 mercury mystique]
Nothing!
Car dies unexplainably. Engine just shuts off and won't start again. Oil light came on and check engine light came on.
Tried cranking it and it doesn't seem to be the starter or anything... and there's definitely enough juice to at least "try" to crank over... but it just wouldn't start. After about 3-4 seconds of trying to crank it over, it would make a noise similar to the screeching sound you hear when you try to start a car that's already turned on. I don't know if that's "new" or not, because the car would typically start in 1-2 seconds...
My battery charge light has been going on and off for over a year without provocation. When I noticed this a year ago, I had checked connections, charge, etc. All fine. Just thought it was "one of those things" that I lived with. Not sure it had anything to do with what happened tonight.
I don't even know where to begin to trouble shoot this... but since I got a CEL, I wanted to pull the codes. I know that there is a manual way to check the check engine light code without using a computer. You use some kind of key to press something, somewhere, and then like "morse code" the light flickers and you can get the code that way.
Can anyone offer (or point me to a post) that has a detailed description on how to do this?
And also, is there a site that lists all the CEL codes and what they mean?
Also, given what I've posted... does anyone have any guesses as to what this could be?
Thank you!
			Nothing!
Thank you!
