mdbsbl8
I am almost done repairing my csvt from an accident I had but I have run into an issue with the airbags. As you can see in the pictures the terminals for the airbags are similar the only difference is the little top clip part. The black one is from the car a 98 and the brown one is from a 99. My question is if I shave the little part off and connect them will it work? Everything else is the same minus that and I don’t want to try it and then have them go off. If they won’t work then I won’t plug them in and just install it in the car like that. Also I know I should get this done professionally but I am on a budget and can’t afford to pay a few thousand dollars on airbags. So please no comments on this is stupid you shouldn’t mess with the airbag system blah blah blah. I am content with driving around with no airbags and as I said if this doesn’t work I will install it just so I don’t have a hole in my steering wheel.
