potential Veyron killer??......?
svt4stv
Los Angeles, CA
saw this at SEMA and grabbed a card. just found it and checked out the info some more online. i was talking to the sales guy there and he said they believe it should hit 270+mph but there arent tires fast enough for them to test on. he said Michellin is working on one.
Ultimate Aero TT
HP: 1,180 bhp @ 6950 rpm
Torque: 961 lb./ft. @ 6150 rpm
Dry Weight: 2,750 lbs.
Top Speed: Up to 273 mph
(per Langley wind tunnel calculations
Engine
Type: Aluminium Block and Heads (V-8)
Displacement: 387.2 cu.in.
Bore x Stroke: 4.125 x 3.620"
Compression Ratio: 8.975:1
Horsepower: 1180 bhp @ 6950 rpm
Redline: 7200 rpm
Fuel Injection: Electronic Sequential Port
Weight: 422 lbs
Oil: SAE 5W/30 Fully Synthetic Racing
Induction System: Sequential, multi-port fuel injection. Twin Turbo Charger with cab adjustable boost pressure. 6 psi, 15 psi, 26 psi. Dual-forced air innercoolers
Fuel: Premium Unleaded - 92 Pump Octane
Warranty
Basic Warranty: 1 Year/Unlimited Miles
Powertrain: 1 Year/Unlimited Miles
Rust-through: N/A
Chassis and Body
Layout: Mid-Engine/Rear Drive
Body/Frame: Carbon Fiber/Composite/Steel Space Frame
Brakes:
Front: 14.0" Vented Slotted Discs/6-Piston Calliper
Rear: 14.0" Vented Slotted Discs/6-Piston Calliper
Wheels: Forged 3-Piece Alloy
19x9-1/2" Front, 20x13" Rear
Tires: Michelin Pilot Sport PS2
Front: 235 35 (YR)19
Rear: 335 30 (YR)20
Steering: Rack and Pinion, Assisted
Turns, Lock to Lock: 2.5
Turning Circle: 41.6 ft.
Suspension:
Front: Unequal Length Upper and Lower A-Arms
Coil-Over Springs/Adjustable Tube Shocks
Cab Controlled Air Lift
Anti-Roll Bar
Rear: Unequal Length Upper Rocker and Lower A-Arm
Horizontally Opposed Adjustable Coil-Over Springs
Anti-Roll Bar
The Dynamics of the Aero
Coefficient of drag (Cd): 0.357
Frontal Area: 19.0 square feet
Belly pan: Complete flat belly pan with rear Venturi tunnels.
General Data
Weight to Horsepower Ratio (lbs/hp): 2.33 New production record!
Weight distribution F/R:
Front: 42%
Rear: 58%
Wheel Base: 105.2"
Length: 176.2"
Width: 82.7"
Height: 43.0"
Ground Clearance: 4.0"
Trunk Space: 2.6 cu. ft.
Accommodations
Seating Capacity: 2
Headroom: 38.5"
Seat Width: 2 x 19"
Leg Room: 47"
Seat Bank Adjustment: 25 Degrees
Seat Travel: 6.0"
Drivetrain
Gear Ratio RPM MPH
1st 3.82:1 7200 44.65
2nd 2.15:1 7200 79.28
3rd 1.56:1 7200 109.27
4th 1.212:1 7200 140.63
5th 0.973:1 7200 175.19
6th 0.656:1 7200 273.75
Final Drive Ratio: 3.44:1
Engine RPM @ 60 Top Gear: 1550
Instrumentation
Gauges:
260-mph Speedometer
8000-rpm Tachometer
Sequential Shift Lights
Horsepower Gauge
Oil Pressure
Water Temperature
Fuel Level
Volt
Audio/Video:
Navigation System
10-Speaker Premium Audio/CD/DVD System
7.5" Video/DVD Screen
Automatic Back-Up Camera
Standard Equipment
Includes:
Air-Conditioning
Power Windows
Power Mirrors
Tilt-Steering
Cab-Controlled Front Air Lift
Record-breaking Times
0 to 60 mph: 2.78 seconds
1/4 mile: 9.90 seconds at 144 mph
Skidpad: 1.05 g
0 to 100 mph to 0: 11.66
60 mph to 0 (braking): 103 feet
here's the link with some video and more pics.
Ultiamte Aero TT
iirc, the price was around $500k, leaving me out :cry:
that and its only 48 state legal, iirc, and guess which state is ruled out immediately? :mad: besides the fact we dont have 92 octane!
sorry for the poor pics. terrible lighting and 1st time using my new camera.
so what chy'all think??
the sales guy there and he said they believe it should hit 170+mph but there arent tires fast enough for them to test on. he said Michellin is working on one.
:shrug: :shrug: :shrug: The car has been posted here. Those are Focus projectors.
hot little car... and a budget compared to the veyron which is 1 million dollars and some odd change.
I was at Sema this year and I dont remember seeing that car... where was it located?
Looks better than the homely Veyron IMHO.
Though the Veyron interior looks to be built like a swiss watch!
And even though that car looks nice, it looks a bit like a kit car.
I'd still trade my SVT for it!
steve i'll bet you 5 bucks they dont sell 6
do we REALLY need another 1000hp supercar for the market? :shrug:
