greasemonkey1489
Lately I have been noticing an issue with my car, especially this winter. The engine would run strong (1995 2.5L MTX) while cold-cool. Then after warmed up (closed loop I'm assuming) it would be somewhat sluggish in the low end (700-3000 RPM), idle rough at times and between shifts, the idle would hang a little. The idle stayed low as well, around 550-600 rpm (especially with blower on med setting and headlamps on). I datastreamed it this weekend after a drive about 10mi out of town @ 55-65 miles per hour so it was for sure warmed up. I had readings a little higher than spec from the MAF and Engine Coolant temp sensor (ECU sensor) and a rich reading from both 02s (switching from .28-.9v every second). I'm thinking the MAF is a tad out of range and also could cause the hanging idle? If anyone can share some input, I would greatly appreciate it. I love the car when it performs well but my fuel economy sucks!! I granny shift and hardly drive spiritedly. Even in the cold, I hardly leave the car idling and I still get 18 mpg in town. Maybe a good cleaning will help?
