Hi All, I got an odd problem and was hoping for some insight. I have a 98 Duratec ATX which has surprisingly had little problems...till now and I'm stumped.
The problem is...she wont start. Its odd, The battery tests at 12.66 volts and is fairly new. All accessories work and the headlights dont look dim or anything. When I turn the key I hear the fuel pump run but the car doesnt try to start. Not even a click or any sound of strain from the engine. So i'm thinking juice isnt getting to the starter or the starter is bad. Its never had a hard time starting before at all. So, i'm hoping its the ignition switch or maybe starter relay? I dunno. Those are obviously the easiest things to fix. Unfortunately my GF parked it on a slant so I cant jack it up to check out the starter right now. I checked all the fuses that should matter and they look fine. Another option is the PATS anti theft thing. So when I turn the key in the ignition...my red led goes solid for a sec...then off completely so I believe thats an indication the pats is working correctly...I think. .... Any help out there would be really appreciated. I need my commuter car back.
Tried to write this up as clear as i could but I just got off of a 14 hr work shift...nights at that, so i'm brain dead at the moment. :crazy:
Thx!
Thx!
	 .  If it is an intermittent PATS issue, 9 times out of 10, disconnecting the battery will reset it and it will fire up right after that.  When you turn the ignition to on, does the Check Engine Light come on for a 5 to 10 seconds?  (to determine if power is going to the PCM-"brain").
