"tony2005 you seem pretty knowledgeable"
ROTFL. :laugh: . So are most CEGers who post answers.
"will my car pass emissions if i gut the cats? also will it stop the light?"
It depends. If you gut the cats, you need mileliminators to prevent P0420 and P0430, inefficient precats codes. If your inspector does not see the mileliminators (most times they don't as it is wrapped up and they assume that it is a universal O2 sensor being spliced in) and all you have is the OBDII check for emissions, you should pass (provided you don't have any other codes lighting the Check Engine Light). If you have smog sniffer tests, then you will have to make sure your main cat is still in good working condition and meet the emission standards of your state.
Can't go wrong with $30 (or $5) mileliminators.
http://www.contour.org/ceg-vb/showthread.php?t=760
" i was told by the people at the e-check that if i could show 300 dollars in receipts that i would get a wavier but that doesnt fix my drivability issues."
Note that usually the waiver has to be due to repairs to get the emissions systems in compliance and the receipts have to be parts and labor from a smog emissions licensed facility or technician. Check with your state or local regulations to be sure.
"it hesitates and surges while driving forward."
Yes, you need to take car of this issue. Start by fixing the known problems.
I will quote Big Jim again,
One of the first rules of troubleshooting is that you fix what you know is wrong and the
 re-evaluate."
