starjammir
I went to put the Live Link on my computer with Windows 7, won't install.
Just a heads up.
Just a heads up.
Mine would not let me finish the install. I found part of the program in my C: drive and did what TX told me to and I just reinstalled it in my computer.i still have problems with it. It wont let me finish the install. Tells me to contact the vendor.
Do what TX said in this post and it works for me
Still doesn't use USB except for a mouse or keyboard.You can try using a virtual machine.
Download Virtual PC from Microsoft (it is free).
Set it up to run XP 32 bit.
then install and run it from within the Virtual XP environment.
Only problem is that older versions of VPC wouldn't see the USB ports of the host. I haven't used it in a while so I don't know if that holds true with the newer versions.
Vmware works with some USB but, at least the version i tried last summer, did not work with SCT and the Xcal2. it would load up SCT just fine but could not find the Xcal2vmware ftw
