Well I think the filter that came with this kit is too long. Im scared of hydrolock especially in FL that everything floods in the rainy season. An suggestions on a shorter filter? Perferrably k&n 3" diameter on the flange to fit the piping.
I believe AEM makes something you can run in-line somewhere before the MAF that will prevent hydrolock.
Joey was able to angle the filter so it was parallel to the road. I wasn't able to do that with mine, below, but I thought that was because I had a Cougar with a 3.0L UIM installed.
http://www.aempower.com/ViewCategory.aspx?CategoryID=20
My brother bought one of those after his CAI sucked some water into his motor and blew a hole the size of my fist through both sides of the block.
Sure does. Thanks for pointing that out. I wonder if there is something with the same concept that can be put onto FI.
