F111D F
Interesting connector round concentric accordion seals around each wire. Pull the plug and meter between the BK/RD and Brn/Wh you should see steady 5vdc. (key on) wiggle the wires? I know it's abit of a juggling act. You should have 12vdc between GRN/Wh and BK/wh.
I have run into conflicting info electrical diagrams on the CD manual, involving this Brn/Wh (Signal return) lead as to how it gets back to pin 91 on the PCM connector.
If should not have 5vdc you need to check for continuity between IMRC connector and the PCM connector. As previous Brn/wh should have continuity to pin 91 and BK/rd continuity to pin 42. While your at it go to chassis ground to each end verifying no continuity/open.
Hopefully it is only a bad connector plug ie broken wire inside the plug?
I believe several others have this same issue always operated P1518?
I'm having trouble finding S48 on the engine big help it's located on the engine ---besides the Sig return from the IMRC at splice 48(partial) is wire from sig lead from O2 front #21, the engine coolant sensor I'm assuming sig return, for those with a manual tranny the TPS , the EPT sensor Exhaust pressure Transducer, and still with the manual here comes splice S53 (also on the engine?)picking up power steering pressure switch sig return. AND the ACT air charge temperature sig return (IAT maybe) and both rear O2 sig returns #12 & #22, the knock sensor sir return.
Damn I just got lost!!! Oh the ATX
For all those with P1518 could it be possible from sensor bad say going to ground or I low enough resistance to ground interacting? For those with a continuing IMRC problem if you have 5VDC on the BK-RD lead the next thing is continuity to pin 91 on PCM plug AND NO resistance readings to chassis ground OPEN. IF otherwise start unplugging all the electronic engine sensors until it's clean. Just never know the possible interactions. Maybe something to CSVT 1214's problem????? It looks like all the signal returns come back to pin 91 on the PCM.
I'll post this for now any questions please don't hesitate I know my troubleshooting/thought processes are confusing.
Does anyone know where Splice 48 and 53 are located besides on the engine? It might help someone isolate easier if they're SIG RTN lead is not clean! Tony
All this before never mind my login timed out while I was re-re-editing.
Interesting connector round concentric accordion seals around each wire. I've having fun well it was until Fluke auto switch over from ohms to voltage well that's what I'm blaming it not mention I was looking plug wrong. Did mention it's cold in the garage.
Unplugging the connector and reading voltages (key on) battery voltage between grn/wh and grd BK/wh. The 5vdc is between BK/wh and BK/Blu.
With key still on resistance ---between Bk/Rd and Brn/wh was approx. 7.8k to 8.7k ohms turn the key off and it went to approx 12Kohms. This goes to 2-3 ohms when I use the scan tool to turn on outputs.
I've got to tell you it's not what I'd expect looking at the wiring diagram provided in the CD manual.
Because according to the diagram the monitor circuit BK/blu 5vdc from the PCM and it's return from contact closer (the motor has pulled the cable is on Brn/wh. That BK/rd lead is from the PCM to transistor the bias control to the transistor I'm guessing. This block diagram stuff makes it to hard troubleshoot the way I'm use to. It really gets interesting when the grandson interrupts to assist him with Star Wars . Seriously without the YES/NO troubleshooting section HU in the PC/ED manual this IMRC a real trip!!!
Of course I never really had any codes on mind, until I start seeing others reporting codes.
I'm knocking on big chuck of wood black walnut cut down and milled and dry locally I hope and pray mine doesn't quit like yours did
Clay SVT change the connector hopefully that fixes it and we'll all run like heck.
