con_svt_tour
New CEG'er
- Joined
- Apr 12, 2005
- Messages
- 10
Are the wheel bearing pressed into the spindle? When replacing the wheel bearing, is this something that I would be able to do without a press if one is not needed?
it is pressed in. You can remove the hub and take it to a shop to be pressed (avoiding removal and replacement labor) or you can alternatively buy a new hub (which comes with a new bearing already in it) and simply remove and replace the hub.
The rears can come as an assembly but the fronts dont normally. Its like that on a lot of fwd cars.
again.. I've ordered (4 or 5 times) the fronts as an assembly. I can't quote pricing or parts availability NOW, but I have done it many times.
