There was a HUGE database I found when finding things to search for when I first started getting into the addictive series of tubes...
I saved the entire list and turned it into one big HTML file... I'll upload it now and post a link.
Don't think it covers 04 cars, but it has A LOT of older cars.
OK, so I uploaded two files... they are HUGE, so open in a new window and let it sit for a bit!
Car Tests - 885KB HTML
Each manufacturer is sorted alphabetically, with each model tested in it's own row. Each column is broken down into the following items, if applicable:
- Automobile Description - Manufacturer/Model/Trim/Year
- EngineDisp - Engine size in Cubic Centimeters (CCs, with 1000cc's in 1L)
- EngineLoc - Location of the engine, (F)ront, (M)id, (R)ear
- EngineType - (N)aturally aspirated, (T)urbocharged, (S)upercharged
- HP - Horsepower/PS
- HP-RPM - Maximum RPM of said HP/PS
- Torque - Maximum Torque (lb/ft)
- TorqueRPM - RPM of said Torque
- CompRatio - Compression Ratio
- Redline - Engine's redline in RPM
- Gears - Number of forward gears
- Trans - Transmission, (A)utomatic or (M)anual
- 1st - 1st gear ratio in "x:1"
- 2nd - 2nd gear ratio
- 3rd - 3rd gear ratio
- 4th - 4th gear ratio
- 5th - 5th gear ratio
- 6th - 6th gear ratio
- AxleRatio - Rear end/Final Drive ratio
- DrivWhls - Drive Wheels, (F)ront, (R)ear, (A)ll
- Weight - Curb Weight
- WtDist - Weight distribution percentage of the front (subtract this from 100 for rear)
- Whlbse - Wheelbase in inches
- TireSectWidth - the "215" in 215/45-17
- WheelDiam - the "17" in 215/45-17
- TireProf - the "45" in 215/45-17
- Cd - Drag Coefficient rating of car
- Height - Height of the car in inches
- Width - Width of the car in inches
- GrndClr - Ground clearance of the car in inches
- 0-60 - 0-60MPH in seconds
- 1/4mile - 1/4mile (1350ft) in seconds
- EPAmpg - EPA combined city/highway MPG
- LatAcc - G-Force on a skidpad
- Slalom - Slalom speed in MPH
- LapTime - Lap time speed (unknown distance) in MPH
- Top Speed - Top speed of car in highest gear in MPH
Here's the "1997" Contour SVT (might have been Goonz's car!):
		Code:
		Automobile Description EngineDisp EngineLoc EngineType HP HP-RPM Torque TorqueRPM CompRatio Redline Gears Trans 1st  2nd  3rd  4th  5th  6th  AxleRatio DrivWhls Weight WtDist Whlbse TireSectWidth WheelDiam TireProf Cd Height Width GrndClr 0-60 1/4mile EPAmpg LatAcc Slalom LapTime Top Speed
FORD CONTOUR SVT 1997      2544      F         N       195 6625    165    5625      10.0     6800     5    M    3.42 2.14 1.45 1.03 0.77 0.00   4.06      F       3270    63   106.5       205        16.0       55   .32  54.5   69.1   8.2   7.85  15.84   21.0  0.859   60.6   190.2     143.7
Wow, that took for-freaking-ever to get the spacing right... wish I could just make a table... damn HTML being disabled
Wanna see how old that file is?
		Code:
		<META NAME="GENERATOR" CONTENT="Mozilla/4.06 [en]C-gatewaynet  (Win98; I) [Netscape]">
Yep, the old Netscape HTML editor is what I joined the sections together with!
I have no idea where the data came from (probly Manufacturer), and I can't find a site with this info anymore, so yeah...
Here's the other file... not as impressive, but still cool:
Car Reference - 223KB HTML - Allows you to cross reference a car if you know the model, but not the manufacturer.
