highspeedjbt
New CEG'er
- Joined
- Mar 26, 2008
- Messages
- 23
First off I haven't been on this forum since 2000 when I got My 1998 csvt. I just picked up a 99 for 1500 bucks. The PO said that the tranny was built by haynes and has upgraded everything with a quaife lsd. He has no proof because he bought the car off of a "friend" of his. Well is was suppose to have a spec stage 1 in it also. The tranny is smoother than I remember my old csvt being so I thought that he was legit. here is the problem that I am having.
-needs a master cylinder or brakes bleed because the pedal is spongy and I have to pump the pedal to get good pressure.
-Clutch slips in 4 and 5th gear, every once and a while, never does it in consecutive shifts.
- while shifting the rpms are slow to fall and if I shift fast the clutch will slip in 3-5 gear.
Do these problems interact with each other or am I looking at swapping another clutch in a csvt(did my 98 and it was a
, even with a lift). I have done the clutch slipping test and this is what I get. 4th gear at 35 mph, floor it then it will slip, then go to 3rd, back to 4th again, 35mph role and then it won't slip..........what the hell...over! Any help would be appreciated. I have been working on DSM's for the last 6 years and they are definitely different then the csvt so I really don't know what to be looking for. Thanks in advance
