Would this bondoglass stuff work on repairing a split-in-two lower section of the SVT front bumper (pretty much the same area as a Mirko)?
The best thing to do here is a straight-out fiberglass repair.  It's not terribly difficult.  Here's what you do:
1. Buy 1 or 2 fiberglass repair mats, fiberglass resin, and some cheap disposable brushes from Wally World or your nearest autoparts store.
2. Sand the edges of your crack down to a shallow "V" front and back.
3. Cut your fiberglass mat into several strips the length of your crack, at LEAST 3 strips for each side.  Make the first one the narrowest, with each strip at least an inch wider than the one that will be below it.
4. Clean the area to be glassed with Acetone. (available at any home improvement store)
5. Mix your resin (only enough to do each strip) in a small container that's large enough for you to get the brush inside.
6. Beginning with your two narrowest strips of glass (one for each side of the Mirko), brush your resin on and then lay on the strip, making sure to keep it nice and smooth and keeping the edges of your crack aligned.  Make sure the resin completely saturates the glass.  Do this for the front and back.
7. Let resin cure.
8. Repeat steps 5-7 for each successively wider strip of glass.  Do this until you have filled in your "V".
9. Scuff sand your repair, clean with acetone, then fill with your filler of choice.
10. Sand, prime, and paint.
Your repair will probably be the strongest point on your Mirko now.  I had to do this with a boat of mine that was hit by a pontoon boat and ripped the fiberglass on the side a good 18".  The repaired side was 3-4 times stiffer than the other side that had not been hit.
Good luck!
