Dumb question
ContourCote10
New CEG'er
So, ive been looking at intakes on ebay and have found some extremely cheap Focus short rams. My question is: Is there a difference between the Focus's SOHC and DOHC intakes? They have just about as many for both. The SOHC ones are MUCH cheaper, and if they would fit i would love to get one.
The SOHC versions are for the SPI engine, not the Zetec. it might fit but i really doubt it. just get the one for the Zetec (DOHC).
By SOHC intake do you mean this?
http://cgi.ebay.com/ebaymotors/00-0...CarQ5fTruckQ5fPartsQ5fAccessories#ht_1264wt_0
Or this?
http://cgi.ebay.com/ebaymotors/00-0...CarQ5fTruckQ5fPartsQ5fAccessories#ht_2008wt_0
If so, I'm very sure it will work. It might take a bit of stretching for the filter and/or coupler, but I think that's what a friend and I both have. :shrug: You can always get a different coupler or a different filter or a different breather hose! I have some of that blue breather hose pictured on the bottom pic, and it works REALLY well and NEVER kinks. It is very stiff.
Bottom one has a better breather hose. Go with that one. Sourcing out a replacement breather hose can be tough...I have dealt with it personally.
It is a give and take though. The top one doesn't have a hole in the 90 degree elbow which he wont fill because he has a 2000 with no separate IAT sensor. It's a matter of either finding better breather hosing or buying a new 3inch elbow.
hmm well i think ill go with the bottom one..its cheaper...and an elbow will be much easier to replace. Thanks guys
The hole comes plugged just in case you don't need it, IIRC.
lol my intake tube is nothing special,cost more then ebay one though,it's just a red flex pipe from spectre performance with the air intake temp sensor beside the battery where all the cold air goes haha, Breathes really great tho and greater throttle response
