I have a 97 ford contour gl. Automatic Transmission, four cylinder engine. The car has 118k miles. I've searched through many other posts regarding the o/d light flashing however my problem seems a bit different. Most peoples problems seem to be with the 2/4 band, though I think my car has both gears.
I will drive the car normally and the speedometer works perfectly. The car does seem to take a while to shift into second gear. The rpms will climb before it does a hard shift. If I let off the gas the car has an easy time shifting into second gear. After that the car seems to get into the gears ok. The O/D light will start flashing within the first 10-15 minutes of driving, always. I remember reading about two sensors, one is a vehicle speed sensor and the other one I cannot seem to find, but I believe it was called a transmission range sensor. Does it sound like the range sensor is my problem? If it's an easy swap out swap in part I will just change it out, but I have never heard of this before. Any advice would be greatly appreciated.
