KenshinSVT
New CEG'er
Hi Everyone!:laugh:
I have been here since a couple of months but never registered , but now, my only hope is your help about this, sorry for bother you in this way in my first Thread.:shrug:
I searched in the old forum and all what I found was the same questions with no accurate answers, so I just want to know how resolve this, with no speculations, there are enough speculations in the old Forum.
The MTX of my CSVT has a lot of problems to shift into 1st, 2nd and reverse when the car is in neutral:nonono: . It doesn't matter if the car is cold, hot, or if is day or night, it happens in all circumstances. I tried pump several times the clutch, but there is no difference, it's like if I want to insert a stick into a solid wall. There are no sounds, no noises, it just don't shift. The only way that I can shift into 1st or 2nd, is turning OFF the car, shift into 1st, and then turning ON the car with the stick in 1st. Other way that I found was shift into 3rd, move the car a little and then shift quicly in to 2nd or 1st.
When the car is running, there are no issues about shifting, just in neutral with the car stopped.
I already changed the fluid with Mobil 1 Synthetic Mercon, but I readed here that the ATF +3 +4 from chrysler work better because the friction modifier ammount, so I changed the oil again with Valvoline ATF +4 Full synthetic yesterday. There were no difference at all. (I didn't buy MTF because im in mexico, and I couldn't find any MTF with the GL-4 specs, just GL-5)
I read in the old forums that could be the pressure plate, the slave cylinder, the forks, well a lot of "...that could solve the issue" posts, but I couldn't find at least one popst saying "this resolved my issue". So, please I beg for your help, I'm already in my knees!!!:help:
Thnxs 4 any help.
Kenshin
Thnxs 4 any help.
Kenshin
